I have never operated an engraver or CNC machine before but have been researching for the last 2.5 months. I have downloaded a few CAM CAD softwares and simulations.
I am trying to decide what type of engraver to buy. I have a very specific case used for the machine. I am putting text on iodized aluminum plates that are coated/painted with enamel. It’s about 100 text characters appx. 4mm text height. I would like to know if Shapeoko 4 Standard size will be able to crank out 1 in about 5 min or less. the Plate is about 5x7 in or 127x177 mm. and the text will be probably no more than .1mm or .2mm deep if that. The plate itself is probably 1.5mm deep if I had to guess.
I’m thinking of using a 30-degree v bit or something like that. I put the simulation in Easel and I had it come out to 6 minutes but I jumped all my setting up to superfast. I guess what I’m trying to ask is this is a realistic option with this machine. I heard the rack and pinion systems are faster. I have no idea the limitations of this machine or the stepping motors’ speeds or anything.
I want a CNC so I can stop using a hand engraving tool because it vibrates my hand pretty bad after just writing one placard. THis is one small aspect of the job that I do so it would only be used for this purpose and maybe only used three to four times a week for one placard each time. Also, I want a professional look and not sloppy shaky handwriting from a hand tool.
I would like to use this at my place of work and have other people be able to use it as well for engraving the same item. I’ve looked at good quality Dot Peen Marking Machines but they are about 3 times the price and kind of not as good software options plus small work area.
As it sits people can usually handwrite these placards in about 5 minutes so I want to make sure this doesn’t take much longer than that as a selling point to management to get this machine. Unless someone knows a machine that would better suit my needs for about 1500 to 2500 USD. The Dot Peen is extremely fast about 20 characters per second, but like I said it’s about 8000 for the full package. & pretty sure the manager is going to dish out that much.
From the video’s I’ve seen the xyz axis seem a bit slow but I’m not sure if that’s just because people are milling larger items and want the quality for how much material they are removing or if the machine just can’t go that fast due to physical limitations of the stepper motors and other parts etc., I’ve seen some Mill Right videos where it looks like the xy is a bit faster. However, I have also heard that Mill Rights customer service is less desirable than what I’ve read about Carbide 3D’s customer service. I have also heard that some of the Mill Right products are not square and that scares me as far as having to deal with the router connected to the carriage and all.
Also, I don’t know much about IPM but I’m not sure that is the best unit when talking about the very small text because there isn’t much material to be extruded anyways. I’m thinking the speed comparison between different machines with this type of engraving would have more to do with the stepper motors, type of xy axis built, etc… Or could I just use a direct IPM comparison between products for this type of engraving to determine which is faster?
Any thoughts would be great,
Thanks,
