TMToronto
(Tom Mandel)
November 10, 2023, 2:28pm
1
I am interested in purchasing the Shapeoko HD 80MM Spindle Mount for the HDZ from the website.
I would appreciate it if someone could provide:
the overall dimensions, and
the mounting hole spacing
Measures to an accuracy of about 5 mm would be great.
Thank you.
Tod1d
(Tod (with 1 'd'))
November 10, 2023, 2:44pm
2
I think you’re going to want something in the neighborhood of 0.05-0.10 mm if you want the screws to line up.
TMToronto
(Tom Mandel)
November 10, 2023, 2:48pm
3
Thank you for your response.
I am designing my own Z axis assembly, and the exact dimensions at this point are not critical.
I am using overall dimensions as a way to compare its size to other options - like that of RoverCNC, and the hole spacing to see if a custom T slot extrusion will be an option.
WillAdams
(William Adams (Carbide 3D))
November 10, 2023, 3:06pm
4
I posted some files at:
Here is only the hole pattern:
Overall dimensions of the current 65mm mount:
Width: ~135mm
Depth (front–back): ~100mm
Height: ~40mm
TMToronto
(Tom Mandel)
November 10, 2023, 3:27pm
5
Thank you for the help and effort.
I am interested in the 80 mm mount shown below - pic from website shop page:
It looks like it only has 4 mounting holes and you show 6.
Also, I am wondering if the dimensions differ from the 65mm to 80mm mount.
The 40mm height is quite narrow IMO for an 80mm spindle if that is the case.
I appreciate the support.
WillAdams
November 10, 2023, 3:42pm
6
Oh. My apologies. I don’t have that.
I suspect it’s similar in dimensions to the 65mm mount on a Pro.
WillAdams
November 10, 2023, 3:44pm
7
Here is a file which has the hole pattern for the HDZ:
Making a mounting plate for mine:
[WIN_20210307_21_55_21_Pro]
Almost got it centered, and aside from that and the two “test” holes the cut went fine — hopefully it fits as well as the acrylic test cut did.
Here’s the file — should fit to an HDZ and the Mafell FM 1000 WS:
hdzplate_adjusted_274.c2d (154.6 KB)
Here’s a slightly adjusted version based on a test fit of the file above:
hdzplate_adjusted_274_v2.c2d (123.1 KB)
TMToronto
(Tom Mandel)
November 10, 2023, 3:53pm
8
Thanks.
Is my red line correct for the widest spacing of the mounting holes?
It is about 95mm, so if the mount is ~135mm as you had measured for the 65mm mount then that may be correct.
WillAdams
November 10, 2023, 4:06pm
9
Yes, the 65mm mount on my SO Pro measures:
Width: ~120mm
Depth: ~90mm
Height: ~40mm
but not sure how the 80mm mount differs from that.
TMToronto
(Tom Mandel)
November 10, 2023, 4:20pm
10
Thank you again - perhaps in time someone with the 80mm mount will join the conversation.
WillAdams
November 10, 2023, 4:26pm
11
I re-opened your ticket and noted how badly I fumbled it — hopefully someone there will step in and provide solid numbers from measurements of the actual part.
TMToronto
(Tom Mandel)
November 10, 2023, 5:04pm
12
No need for apologies. I know what I am asking is very specific and not necessarily everyone would want to help, staff or otherwise.
I am extremely appreciative of the time and effort you have already dedicated to helping me.
I know many manufacturers make such information readily available in their online documentation, but perhaps it depends on, and supports, their business model.
I remain hopeful - and thank you again
