About to scream!
I have upgraded your account to a Regular member, so you should be able to upload multiple images in a single post.
For text, it is necessary that the narrowest region be a bit wider than the tool in question, and it helps if the tool is markedly smaller than the width of the text — unless one is cutting wood and can use a V carving toolpath (not suited to plastic).
For a work-around see:
