I bought a Dewalt 4 Gallon portable vacuum (its a DXV04T) to use on my router and the hose is not fitting my Sweepy 2.0 dust boot adapters. The adapter has an OD of 1.620" while the hose has a 1.570" ID. Anyone else found themselves in the same situation and have any suggestions for another adapter to go between them or a hose that i can replace the std hose with?
Make your own?
I bought this, or something like this, to work between my DeWalt DXV08SA shop vac and the Sweepy 2.0 dust boot. I took off the ring strap on the smaller part, and it fit perfectly in the dust adapter. The end of the hose from the shop vac was a little loose so I just clamped it down with the hose clamp.
https://www.lowes.com/pd/Fernco-1-1-4-in-x-1-1-4-in-x-1-1-2-in-dia-Coupling-PVC-Fitting/1000075247
edit: found my receipt. here is the actual one I bought for my CNC.
https://www.lowes.com/pd/Fernco-1-1-2-in-x-1-1-2-in-x-2-26-in-dia-Coupling-PVC-Fitting/1000075239
Maybe something like that would work? Found this in the plumbing section at Lowes.
