Making vacuum hose adapters
While cutting up vacuum extension wands for this is expedient, it’s a bit problematic given that Shop Vac recently filed for bankruptcy, was bought at the last minute, and production hasn’t caught up.
I need a receptacle for the Sweepy 2.0 dust fitting — one option would be to purchase one from Woodcraft, but Carbide 3D sells blocks of HDPE:
which looks to be just barely big enough for things to fit.
Measuring the hose fitting I get a diameter of ~63.5mm — offsetting that twice we arrive at:
which it is pretty straight-forward to render toolpaths for:
but this thickness stock raises the concern of rubbing and tool engagement, so we add some geometry to take this into account and rework the toolpaths to follow best practices.
The first consideration is the endmill to be used. The best endmills for plastic include single flute tools such as:
which has a cutting length sufficient for our purposes
So, we offset from the perimeters by that endmill diameter plus 10% or so:
Select the inner paths and assign a pocket down to tab depth (1mm):
Select the geometry for the outer wall (not the flange at the bottom) and the offset path from the flange and assign a pocket down to the height of the flange:
Then select the flange and its offset geometry and make a pocket from there down to tab height:
Lastly assign paths with tabs to finish cutting the parts out:
and
Attached.
2_5 hose adapter.c2d (183.5 KB)
Cutting went well:
(except for the extra vacuuming the open sides of the cut engendered)
and the fit is quite secure:
