Design file to cutable file, HOW?
For a CNC, it is usual to cut in multiple passes — remember you’re using a tool which doesn’t have positional feedback — each time it tries to make a motion you have to ensure that the forces involved are such that the machine will be able to make the step with essentially absolute certainty.
Where possible avoid slotting and add geometry and cut as a pocket
and/or
For an example of testing see:
