Local Maintenance
For sizing things, if the machine is mechanically sound, other considerations are:
  • feeds and speeds
  • toolpaths
  • adding geometry and cutting as a pocket down to tab height/the penultimate pass and leaving a roughing clearance — where possible avoid slotting and add geometry and cut as a pocket
and/or
For a belt-drive machine, see:
and I’ve found it helpful to adjust the steps/mm (probably because I’m unable to get equal tension on X and Y), c.f.,
