gmalehooah
(Laurent Riendeau)
November 16, 2023, 1:10am
1
5x7.c2d (64 KB)
A simple tray.The tray part no Problem, the contour where i,m having trouble. It starts at the right depth then runs itself to the bottom in about 5 inches. This is happening about half the time i make trays. any suggestions would be appreciated.
mhotchin
(Michael Hotchin)
November 16, 2023, 1:26am
2
Could your bit be being pulled out of the collet? Collets do wear out over time…
Mark the bit when you insert it, check to see if it drops.
WillAdams
(William Adams (Carbide 3D))
November 16, 2023, 1:27am
3
Rather than cut a slot just as narrow as the tool — where possible avoid slotting and add geometry and cut as a pocket
While cutting up vacuum extension wands for this is expedient, it’s a bit problematic given that Shop Vac recently filed for bankruptcy, was bought at the last minute, and production hasn’t caught up.
I need a receptacle for the Sweepy 2.0 dust fitting — one option would be to purchase one from Woodcraft, but Carbide 3D sells blocks of HDPE:
which looks to be just barely big enough for things to fit.
Measuring the hose fitting I get a diameter of ~63.5mm — offsetting that twice we arrive at…
and/or
One technique which is often suggested to avoid slotting is to add geometry around a part which one wishes to cut out and cut as a pocket down to tab depth — here’s one technique for that.
In this case, the project is a bevel gauge which will be cut out of 0.0625" (~1.5mm) thick aluminum:
[bevelgauge]
Due to the narrowness of the angles, an 0.03125" endmill has to be used, so after importing and scaling the file (we will be cutting out one which is 3") we select the perimeter and offset it tw…
One which has a cutting flute length equal to or greater than the thickness of the stock — pretty much any tool should work.
Big thing is the toolpaths — if cutting out, rather than just cutting a slot:
[image]
Offset to the outside by endmill diameter plus 10% or so:
[image]
[image]
[image]
Then cut as a pocket:
[image]
down to tab height or the penultimate pass:
[image]
then move the contour down to below the pocket and start cutting at the bottom of the pocket:
[image]
and…
gmalehooah
(Laurent Riendeau)
December 4, 2023, 1:29pm
4
This was my problem just not tightening it enough.
system
(system)
Closed
January 3, 2024, 1:29pm
5
