Adding tapered bit to CC Pro
I am fairly sure this has been asked but I can’t seem to find a definitive answer. I am looking to add a tapered ball nose bit the Amana 46282-K. Are these bits supported/addable in CC Pro. If the are are they a considered a v bit? Thanks
Tapered endmills are not supported in CC (Pro or not), but you can fake it as a ballnose endmill the same diameter as the tip radius of your tapered endmill, and for most designs it works out ok.
I did exactly that recently
Thanks. That is what I did and nice to know that it should work. Impress work by the way.
