Bought a diamond drag bit to engrave aluminum and try as I might, I have ABSOLUTELY NO CLUE about how to add a tool.  I’ve purchased other end mills ((1/8th shank) of various size and feel like Einstein’s poster child for insanity.  I’ve watched videos… and nada.
So, let’s leave the dumb as a rock momentarily… anyone using one of the drag bits?.. are you saying you are using a v-bit in Carbide Create… your input is appreciated.
Cheers,
Scott
From Canada’s ‘left’ coast
The official docs on this are at: https://docs.carbide3d.com/assembly/carbidecreate/video-tutorials/#toolpaths
Further notes:
If you select a tool before clicking on “Add Tool” the selected tool will be used as a template for the new one.
- Toolpath
 - Edit Library
 - Add Tool
 - double-click on the new tool to go into edit mode
 - edit as needed
 - Ok
 - close window
Further discussion at: Can CC make use of a diamond drag bit?
