gunter511
(Gunter )
1
Hi All,
I need to cut 10 x 16mm (5/8") diameter discs per run out of 1.5mm thick brass.
Which endmill would you suggest would give me a fast cut time
with the least stress/wear & tear on the end mill.
I’ll be cutting on the Nomad 3.
Many thanks in advance.
Gunter
WillAdams
(William Adams (Carbide 3D))
2
I would suggest a coated endmill, and see how single flute work out — see the videos on these concepts at:
system
(system)
Closed
4
