WillAdams
(William Adams (Carbide 3D))
January 14, 2022, 11:50am
2
This was pretty thoroughly discussed here:
I’m trying to get my S3 XL ready for a lot of aluminum (sheet mostly) work.
After reading so many posts on choosing among the drive options, here is my conclusion. Please chime in if you feel otherwise, and why.
Water Cooled Chinese Spindles:
Pros:
Lower tool noise, however, the noise of cutting material is the same. Spindle owners consider it a substantial difference.
Speed controlled via software.
Precision mounts.
Higher torque, but not really relevant due to the overall limitations of t…
Ultimately, I did get a Mafell FM 1000 WS:
Hi Guys,
I just found that Maffell got two new spindles out with a manual quick tool change.
FM 1000 PV-WS
https://www.youtube.com/watch?v=s1cJW_xCCQs
what you are thinking about ?
did some of you is already using Maffell spindles ?
The only thing that keeps me away from this are the Brushes… i am using a Chinese spindle and that thing performes super and it is very quiet even with air cooling im around 60db. (without load)
But a missing tool change always bothers me…
what are you thinki…
but not so much for intrinsic considerations as that I was doing a lot of test cuts and some days it felt as if I spent more time wrenching than cutting. It’s still on my SO3 XL, and I use an ER-11 Carbide Compact Router on my Pro which is where I’ve actually been doing work lately.
