Just getting the Carbide 3D Shapeoko Pro 4 XXL setup and I must say the process has been much more enjoyable and efficient than my previous Shapeoko 3 XXL.
Anyways, day 2 and at the very end I went to plugin and do a hello world and nothing happened… Perhaps this is some problem with the power supply, wiring, or controller?
I though this was maybe because the new model was silent on start up but after some investigation and tinkering I am not sure what is wrong. The SO3 gave an audible “dunk” on power on and the motors became stiff. Not the case here.
First off the power supply lights up green. Though when I plug it in nothing happens on the controller. With or without any other motor/sensor cables attached. The power supply is definitely firmly attached and the rocker switch does nothing in any configuration. I did not feel dexterous enough with the multimeter to probe the tips of the 24v DC power supply but I thought maybe the switch is broken?
For the USB I ran Mac OS Prober but it detected no signal in any port. I of course downloaded the latest versions of Carbide Motion, restarted the computer, unplugged and replugged the cable, but to no avail.
Inside the enclosure I saw a status LED on the rear of the enclosure between the USB and Power Supply Ports but it never turned on. I of course tried all of this with and without the enclosure lid on in case there was a photo diode preventing it from turning on if the lid was off or something.
Inside there was also a small button which I pressed but this was after initial diagnoses had failed and the button did nothing. I thought maybe a rest button or something.
Everything arrived in great condition with tons of padding and no weirdness anywhere else so I don’t think it got hit in transit but who knows.
Anyways, this could also be a TOTAL NEWB mistake and maybe I forgot a step because it’s late but I tried my best for now and didn’t want to mess anything up trying to troubleshoot further before checking in with you all.
Have any ideas where I might be going wrong here?
Thanks!
