No, parallel should be fine but can you elaborate on the wiring of those two switches in you setup, with closing the feedhold loop on one hand and the separate 12V power supply on the other hand?
With a 12v 1A supply, LEDs rated for 12v should give ‘good’ brightness. How bright will depend on the spec. Dim light suggests one of two things: either that 12v is not the rating, or that the return path (ground or 0v) is not present but the current is in fact flowing into the feed hold input on the ShapeOKO control board - not a good idea in case the input is damaged by this, nor providing enough current ‘sink’ to allow the LEDs to shine.
You mean there are LEDs embedded in the switches? Are the switches rated for mains voltages? Do they have separate wiring points for the LEDs?
Could you take some photos of your setup?
What I’m thinking is that maybe the switch is intended for mains voltage and the LEDs embedded in it are powered by some small internal circuit which provides them with 12V from 120/240V.
Can you clarify this? A transformer is inherently an AC device, it doesn’t work with DC. By “transformer”, do you just mean an AC/DC converter (power brick)?
That would mean my “mains voltage” idea above is likely bust…
You want to run parallel. You’re splitting voltage running in series. A 1A supply is more than enough for two LEDs.
Just keep the two circuits, led power and FeedHold signal, separate.
Were they ever bright? Perhaps just for a second when you first connected them? It is possible that if there are no in line resistors the leds could have burnt out pretty quick and dimmed.
I don’t think the voltage specification indicates any kind of current limitation. He said it is a 1a power supply. Unless voltage drop on the led is equal to the 12v power supply (Or likely higher depending on the quality of the psu) he would need current limiting resistors. In most designs I’ve seen, additional current limited are put in as another layer of protection.
You can put all you want to reduce the current at 12VDC applied, but when it says “12VDC” or some other voltage then there is a current limiting resistor internal to the switch. Trust me.
With one connected it was brighter than the existing one, so I assumed changing to a slightly more powerful plug-in PSU was the answer - but with two LEDs? Nope!
What @neilferreri said. I’m wondering if they shouldn’t be connected in series, rather than parallel, after all. I’ll check when I get home and I’ve got two spares if I blow them
If one is getting brighter when you unplug the other, and you’re sure they’re in parallel, then either you have a short circuit somewhere or you’ve been scammed on your power supply. The supply isn’t able to source the current required, so its voltage is dropping out. Measure the voltage across your power supply with one and two LEDs connected and let us know what it says.
A red LED typically takes on the order of 20 mA, maybe 100 mA if it’s especially big/bright. There’s no way that your LEDs are rated to draw more than 500 mA each.
Can you try placing a known load (capable of dissipating up to 12 watts) across the supply and see how it behaves? Is it sourcing the current you expect for that load?
Cheap or counterfeit power supplies would be nothing new to Amazon. It’s more likely than the switch/LED not behaving as designed.
