Would acetone remove milling marks ? I always wanted to cut a cube of acrylic into something but I never found a way to clear the surface.
Yes. They need to be relatively flat & smooth to start with. i.e. sand down to at least 220 grit if necessary. Super light application. You donāt want it dripping. Let it completely evaporate & reharden. Additional applications if necessary. It takes some patience, for sure. (and a very clean environment, like a paint booth)
It is hard and unforgiving but thatās not a bad first try at all.
If you donāt like the glue process, maybe thereās a world where you still cut the channels for alignment but you just polish them and use brass threaded inserts for final assembly ![]()
Youād have to be creative with it to make it look nice and Iām not sure what fewer fastening points would do to the acoustics but it might be worth modeling up if youāre still looking to produce more.
Iād still love to hear your thoughts on the acoustic performance of the acrylic vs mdf if you do load the electronics into it ![]()
Thanks. I am going to replace two of the acryllic plates that were ātoo aesthetically compromised for my tasteā and hopefully do the final assembly with the acrifix 0192. Using acetone might not be the best for a speaker that basically includes a subwoofer section. When done, I can tell you about the audio experience (but my expectations are good).
