or possibly mix wood and plastics: carve a plain pocket in a large piece of wood, with no details inside the frame, fill it will blue epoxy, surface it once hardered, vcarve the white text, fill it with white epoxy, surface when hardened, vcarve the anchors, fill with black epoxy, etc…you end up with the image as shown. You could even mill away the wooden frame afterwards.
Multi-color epoxy inlays are fun and straightforward. Or maybe I just hate painting and prefer pouring epoxy, I don’t know
This little sign is ¾" PVC. It’s been outside, facing south, in Ohio for almost 3yrs. Still looks the same. Holding up better than the cheap cedar the playset is made of.
I use PVC a lot. It cuts very well. I use the 1 inch which is actually 3/4. Look at home depot or lowes under Royal Building products. You can get it in boards 5.5, 7.25, 9.25, or 11.25 wide. Home Depot also has it in sheets.
I do a lot of signs for conservation properties in my area (volunteer work). We have been using a lot of Colorcore which is a bit pricey but makes a nice sign. You can get smaller quantities: https://www.inventables.com/categories/materials/plastic/hdpe
MDO is just a good quality exterior plywood with a treated paper surface. It takes paint well and doesn’t check like rotary cut exterior plywood does. You do need to seal the edges, so carving it would seem to defeat it’s biggest advantage. If I were making it for myself I would joint up some wood-- but I’m CHEAP. If your doing it for money, I would go with the plastic. I have never used it so I am curious what paint and primer works best.
yeah, again my instinct is “what’s the best wood for this” but it sounds like the PVC might be the easiest. unfortunately i’ll have to factor in the cost of plastic-approved paint as well
Rust-Oleum rattle can.
I’ll look around the basement later to see if I can find the exact can. I use oracal oramask (I think it’s 813) to mask, V-carve, paint and peel off the mask.
This was cut out of 1/2 x 11.25" PVC. I used the smooth side up and the wood grain on the back. For paint black was rustoleum rattle can for the other colors I used some acrylic paints then sprayed a clear coat over when done. I do not have a picture it finished, I will have to get one later on.
Big fan of PVC–like many others on here. I wouldn’t consider anything else but Teak for natural wood. Cumaru is a Brazilian Teak that is relatively inexpensive and stands up to weather exceptionally well. I get Cumaru at Woodcraft store, and it’s super solid and carves well on a CNC. You could glue up a few boards.
If I were in your shoes, I would look into those two for your options.
For my outdoor projects, I typically turn to cypress. It’s readily available at my lumber store in the Atlanta area. My wife and I have a rental house on Pensacola Beach, completed in 2006. It faces due south and takes on the sun all year. A friend and I made the fish shaped railings, shown in the picture, out of cypress, 150 of them. To prep for house repainting, I just replaced 4 of them after 16 years, including numerous storms and hurricanes. I cannot imagine what the cost would be if I used any other material.
i’lll definitely keep all these great ideas in mind. I went back to my guy and said i can make it all out of wood and seal it against the elements and i told him the price
havent heard back…i might have spooked him with the number
