mhotchin
(Michael Hotchin)
September 15, 2022, 3:44am
1
Using a background image is severely lacking. There’s no way to reposition it relative to stock, and no way to re-scale it after its been loaded.
The background image should be a first-class object, and should share the same editability as other objects, like rectangles, including:
Repositioning
Scaling
Rotation
Flipping
As it is, right now it’s almost useless for designing around an existing object.
Zman
(MICHAEL ZEMANEK)
September 15, 2022, 4:11am
2
If simple I trace the image by hand, It has been hard. Normally I just import it and trace image. That has worked well.for most of them
mhotchin
(Michael Hotchin)
September 15, 2022, 4:19am
3
Unfortunately, the project I have that I want to add to is very dark. The contrast is too low for image tracing to get a good render.
Zman
(MICHAEL ZEMANEK)
September 15, 2022, 4:48am
4
I understand.
You can change the threshold. It doesn’t always work well.
Tod1d
(Tod (with 1 'd'))
September 15, 2022, 11:05am
5
You can scale & adjust the opacity when you import it (or after).
I just trace at the scale it comes in, then adjust the vectors afterward.
You can move all your other stuff to layers and hide them.
You can also edit the image to have more contrast before importing it.
It is however, odd that you can’t remove the image once it’s imported. You can hide it, but it still remains in the file.
WillAdams
(William Adams (Carbide 3D))
September 15, 2022, 11:35am
6
When you import a pixel image it is possible to:
Scale it — there’s a control for this
Reposition it — this is done by click-dragging
For an example of re-drawing an object in a useful fashion see:
I’ve searched, honestly, but I still can’t find out if the importing of images is fixed, or I’m just doing it wrong.
Essentially, I drew around a spanner (wrench) with the intention of scanning it, editing the image in Affinity Photo, and then importing it as a background, to draw a vector over it, or as a vector.
Except, it’s either the size of the Eiffel Tower:
[Screenshot 2020-11-09 at 17.28.40]
or the CN Tower in Toronto:
[Screenshot 2020-11-09 at 17.29.38]
Oh, and the stock size is …
Pixel objects are quite different from the vectors which the program works w/ so supporting them beyond what is already done would be quite a change and would complicate the interface quite a bit — the most expedient way to address this would be:
import the pixel image into Carbide Create — measure it there using its tools
close the file
open the pixel image in a dedicated pixel editor — rescale as necessary and perform any other necessary alterations
import the modified file
system
(system)
Closed
October 15, 2022, 3:44am
7
