Upgrading to a spindel on mw 3xl. I need to find the male or female socket so i can plug in and contact the correct pins . Name or part number to source.? Thanks. Tom
See:
Will, thank you. I ve got the 2.2 kw , my concern as to the weight has been commented by many. The recommendation is to use a gas strut. Ive got a HDZ for my Z, but wonder how the gas strut assists and where it’s connected . Seems it would add work to the screw drive on “Z”. Tom
appreciate the HeadsUp on the adapters.
Got the adapter from Amazon, nice assortment of 6 types and shapes with solder pins.
Needing to know the pin out of the bit runner that will control the triggers to the VFD terminals for spindle control. There are 6 options, I need to figure out the two I need to use. Is the pin layout located somewhere, it’s not in the shapeoko manual. ? Thanks Tom
Carbide 3D’s gas strut is only for the Shapeoko 5 Pro.
