Bit Zero unable to probe
Would anyone know why my bit zero keeps getting pushed out of the way when trying to probe?
I did take the collet out and put it back in, would that have anything to do with it?
Does it test as working before each use?
See:
Thanks will try later today Worked just fine after I took the end mill out and put the pin in
Perhaps the endmill was dirty & not making electrical contact with the BitZero. When using end mills with the BitZero, they have to be clean of cutting residues to make proper contact. I usually use a bit of rubbing alcohol & rag or shop towel to clean off bits
And doing a quick touch test with the BitZero to the end mill before running a probe operation usually indicates whether or not the end mill needs cleaning.
Thanks I will remember that!
