Using/verifying the BitZero
Here is how I check out the functionality of the machine/BitZero:
  • first check that you have sent the correct Z-axis configuration
This can be easily done by jogging down to the wasteboard surface, setting zero, then using the Rapid Position command to lift 6mm above the current zero — measure how much the machine moved — if it’s wrong:
  • open the Log Window
  • go to the MDI (EDIT: Note that it will need to be enabled in options in current versions) and send $$ and check that the Z-axis steps/mm match your machine setup:
    • Belt-drive: 40
    • Z-Plus: 200
    • HDZ: 320
      ​c.f.,
Then, clamp a suitably stable piece of stock to the machine:
Initialize the machine, loading a suitable probing pin, allow Carbide Motion to measure the tool if a BiSetter is enabled, and position the BitZero, and jog the machine into position relative to it and attach the ground lead:
click on the “Probe” button in the Jogging pane, select the appropriate BitZero type (if using a version of CM which queries that):
Select the desired probing cycle:
(we will use “Corner”)
Follow the prompts:
“Begin Probe”
​Ensure that the BitZero unit does not move while probing — if it does, repeat:
Remove the BitZero and ground lead and jog to verify the positioning — the Rapid Position Pane has buttons suited for this:
Rapid to current XY
​Rapid to Current Z+6mm
If one has a 6mm dowel it can be used to verify Z, or jog up by 0.35mm and check w/ the shaft of an endmill or a precision rod:
To further verify, one could load a V endmill which makes check XY easier — loading a suitable endmill and facing off the material and repeating will allow measuring the Z.
When positioning the BitZero so as to probe Z only, it may sometimes help to drape the cord over an empty endmill box or something similar so as to ensure it doesn’t tip:
When testing with the new Carbide Motion, things happen a bit differently, but the result is the same.
Download 635 from:
After installation, launch the program:
(if necessary, configure per: Shapeoko Machine Setup )
Connect:
Initialize:
and the machine will initialize and then move to the front.
Clamp stock on the machine:
position the BitZero on it appropriately for the sort of probing which one wishes to do:
Verify that the ground lead creates a signal:
Install a probing pin and position the machine so that it is over the circle to begin a probe and clip on the ground lead:
and test that the ground lead works as expected by touching the probe to the tool (no photo — only have two hands)
Then probe — if need be, choose the appropriate BitZero type:
Select the correct tool:
Next
Begin Probe
The machine will:
  • probe down to find Z
  • lift, then move left, then down, then probe right to find X
  • lift, move right, then forward, thend down, then probe towards the back of the machine to find Y
  • lastly it will lift, move back and left and if the BitSetter is enabled will prompt:
Ok
at which point it will measure the tool — it will then return to the Probe position, where if one removes the unit and uses the CM interface to Rapid Position to XY and Z zero:
One will find the machine has found the origin relative to the probed stock:
There is also a video on this update:
