i just got my bitsetter v1 in the mail and the card that gives you the link doesnt show the v1 only the v2 any help or a link thanks
The installation is the same for v1 or v2 (v2 needs an adapter cable on older machines).
Then, just choose v1 when probing:
see:
I’m trying to put the bitsetter v1 onto my 3 xxl. i already have a bitzero on the cnc machine.i know how to set it up on the computer later
Which sort of homing switches do you have?
Do you have the PCB Splitter Board?
Post photos showing what you do have and your controller?
So it came with a board and i put the splitter wire that came with the bitsetter into where the bitzero was plugged into then connected the bitzero and bitsetter to that board where they said to on the board and then zip tide it out of the way
Looks good.
That extra wire is only needed on older boards which don’t have the Reserved header.
If you update to proximity switches then you can dispense with the PCB Splitter Board and instead plug one accessory into Reserved and the other into the P(robe) connector on the PCB Expansion Adapter.
but how i have it right now is fine? and thanks for the help will
Yes, that’s how one connects them with mechanical homing switches.
