I’ve recently installed a bitsetter on my Shapeoko 3.
After changing tools the z height is off by 1.75 mm…
Procedure:
Carefully zero the z height with some tool.
Use the “Load New Tool” function to put in a different tool.
Watch the bitsetter, measure the tool.
Use the “JOG” function to move to 0,0. (allow the bitsetter to measure again)
Carefully lower the new tool until it just touches the workpiece… the z height at this zero location is reported at 1.750 mm
This is repeatable…
How can I adjust the offset of the bitsetter?
Here’s the debug info just in case.
Machine: Shapeoko
GRBL Version: 1.1f
Carbide Motion 618
Machine Controller State: INIT
Grbl Cycle: Idle
“bitRunnerEnabled”: false,
“bitSetterEnabled”: true,
“bitSetterX”: -1.0,
“bitSetterY”: -399.5,
“bitZeroType”: 1,
“connection”: 1,
“lastConfigSent”: 0,
“lastProbeIndex”: 0,
“lastSizeOption”: 1,
“odometer”: [
“cleared”: false,
“minutes”: 77.33558333333328,
“startDate”: “2023-10-29”,
“travelX”: 199967.1035078466,
“travelY”: 69872.3267493248,
“travelZ”: 40323.249931275845
“showCarbideRouterRpm”: true,
“spindleType”: 0,
“travelX”: -830.0,
“travelY”: -430.0,
“travelZ”: -100.0,
“version”: 0,
“workOffsetX”: 787.2749998092652,
“workOffsetY”: 352.42499980926516,
“workOffsetZ”: 18.400000000000006
0 = 10, Step pulse, microseconds
1 = 255, Step idle delay, milliseconds
2 = 0, Step port invert, mask
3 = 6, Direction port invert, mask
4 = 0, Step enable invert, boolean
5 = 0, Limit pins invert, boolean
6 = 0, Probe pin invert, boolean
10 = 255, Status report, mask
11 = 0.02, Junction deviation, millimeters
12 = 0.01, Arc tolerance, millimeters
13 = 0, Report inches, boolean
20 = 0, Soft limits, boolean
21 = 0, Hard limits, boolean
22 = 1, Homing cycle, boolean
23 = 0, Homing dir invert, mask
24 = 100, Homing feed, mm/min
25 = 2000, Homing seek, mm/min
26 = 25, Homing debounce, milliseconds
27 = 3, Homing pull-off, millimeters
30 = 24000, Max spindle speed, RPM
31 = 0, Min spindle speed, RPM
32 = 0, Laser mode, boolean
100 = 40, X steps/mm
101 = 40, Y steps/mm
102 = 40, Z steps/mm
110 = 10000, X Max rate, mm/min
111 = 10000, Y Max rate, mm/min
112 = 5000, Z Max rate, mm/min
120 = 500, X Acceleration, mm/sec^2
121 = 500, Y Acceleration, mm/sec^2
122 = 400, Z Acceleration, mm/sec^2
130 = 845, X Max travel, millimeters
131 = 850, Y Max travel, millimeters
132 = 100, Z Max travel, millimeters
Maintenance:
Travel (km) 0.20, 0.07, 0.04, 1.29 Hours since 2023-10-29
Queue Empty
