Manual online is old and not for the Pro 5.
Anyone have a link to how to set this one up?
Thanks
Thanks
See:
and
Just pick the right version, v1 or v2 in the Probe window.
Can you attach the little magnet to the bit and do the probe with that or do you have to switch out the bit and use the little metal bit-like proby thing that came with the bit zero?
If the tool and any coating are conductive, then probing can be done with a tool. Note that results may vary based on tool geometry β better consistency will be had with a probing pin (which is why they are included).
