I want to experiment with some box making using box joints and was wondering if there was a way to do this using just carbide create? I’ve made some dogbones using the rectangle corner tool and using the grid and ruler to manually try and get the spacing right but I suspect this will lead to my joints being just slightly off enough that the pieces won’t fit together correctly. Is there any tool in CC that I could utilize to ensure I get the joints set up correctly?
See:
and
That said, it’s a lot easier to just cut the parts and the joints flat on the machine, see:
and
