UHMW and HDPE are pretty similar when it comes to melting points. That being said I just did HDPE and UHMW milling back to back same speeds and feeds and proper chips formed for both but the UHMW did leave a little bit of tiny fur… but almost not noticeable compared to HDPE.
These cutting boards say that they are Polyethylene. The way they are cutting though does not seem to match HDPE which is what I thought they were.
Ah, Polyethylene and High Density Polyethylene are different substances, one of them has the machining properties of French Cheese…
I see no reason why that shouldn’t be @Julien’s next test material. I bet it won’t show the microstepping like acrylic does.
I can’t hear you, your voice sounds a bit horse.
@LiamN those isolators came in. Going to mess with them tomorrow. Hopefully by this weekend I will be able to set the RPM by PWM.
Try to avoid slotting — the constant high tooling engagement makes workholding more difficult among other problems — add geometry and cut as a pocket:
Thanks for the advice! I know I’ve heard that a few times but didn’t actually think to do it.
Meaning it too is “easy to machine” as mentioned here on page 2? Eplastics also has fabrication/machining guides for some plastics that may be useful for acrylic.
I was more going on the lower melting point, tensile strength and hardness all of which can make cutting it with a high speed router bit quite tricky as chips will melt and go stringy very easily compared to it’s higher melting point, harder cousin. I have found that it saws very easily, laser cuts very well (with suitable fume extraction) and water jets nicely. Perhaps with water or air jet coolants it will also cut well on a router machine?
Honestly I think you guys are making too big of a deal about this. They are 3 dollar cutting boards. I got them because I figured the torque requirements to machine it are low so it would be a good initial test.
For me it’s more about understanding which materials we can cut and how to cut them effectively.
I am keen to see the cheese experiments, particularly the workholding, I suspect some of the more Brie like cheese may need freezing before machining…
Would need to find food grade end mills if you want to eat the cheese. Not sure how well stainless steel would work for that. I know you can water jet cheese.
What are you going to call this thing once it’s done?
A Modkita? Something else?
So at 10k RPM plunging into oak with a 1/8th in single flute end mill the ODrive is maxing at 7.43A. I have it current limited to 20A so there seems to be quite a bit of head room.
Already got the hashtag going lol. The VESC is still working great with zero tuning but limited to manual app computer control.
Really really impressed on the performance, even without running a fan. Marv from KERN asked me to do some high power high rpm tests, after this Z is done we’ll push it!
It was 1/4 in. Very nice graphs.
Sensorless Read Velocity is the electrical velocity (Ve).
RPM = Ve * ( 60 / ( PolePairs * 2 * pi ) )
This motor has two pole pairs so:
60 / ( 2 * 2 * pi ) = 4.7746
thus:
RPM = 4.7746 * Ve
I am curious how you are deriving the watts.
