Ok I have posted something similar before but have not found a solution to what I must be doing wrong. This is the scenario I a having happen when trying to flatten a board on my CNC (cutting board)…
I set the program making sure to Zero Out the x,y, & z coordinates - machine runs perfect
The problem is that at times I need to run the EXACT same program again to surface a bit more so here is what I do…
A. I go back into the setting and leave X & Y alone however I do zero out the Z access because obviously the surface is a bit lower than previously
B. After doing this the machine will ask me to install the surfacing bit which I do and it goes through the normal process
C. When it begins it spins up normal, it then moves to the correct place, then disaster…
It buries the surfacing bit and the machine gets stuck which forces me to turn off the machine and wait at least 20 minutes for a reset.
How can I simply run the same program without this happening…it is very frustrating?
