I’m planning on adding an air nozzle to blow wood chips out of engravings and such. In fusion I can select coolant on or off for a bit. So if The control board supports coolant control I can use a valve to automatically control air flow to the nozzle.
You’ll want to look into the A3 pin.
Well thanks for the info. Looks like CM doesn’t support it though and I’m happy with it and not interested in changing programs.
Guess I’m just going to have to have a valve like a cave man. Or I can put a electric switch in.
