Can you use expressions in Advanced V Carve?
I make a lot of catch all trays and my stock material thickness varies a couple of millimeters from piece to piece. As such, I’ve made my designs to use expressions (like t-1) as much as possible. When do this in the Advanced V Carve tool dialog, I’ve encountered a problem when cutting the file on my 5 Pro. The machine lowers too far down and bumps the bottom of the pocket (cut in a previous tool path) and then is raised ever so slightly above the pocket bottom so that it does not actually make a cut. In this instance I have the start depth set as t-4.9 and the max depth as t-4.2. That should make a cut that is .7mm deep, but that is not what is happening on my machine.
So my question is, should expressions work in Advanced V Carve?
They should work, but note that V carving toolpaths are somewhat dependent on geometry.
Please try the new beta:
and if you get an unexpected result in that let us know and we will look into this with you.
Thanks Will. I’ll consider trying the beta version of CC. I’m a little reluctant to try it because I’m trying to limit my self as the only major variable while I learn all of this stuff. lol
