763 is up at Carbide Create Beta Downloads
- (NEW) More accurate selection with elements that are very close together.
- (NEW) Persist the toolpath volume settings between program runs.
- (FIX) Keep empty curves from being created by tracing.
- (FIX) Small layout change in the toolpath pane.
- (FIX) Deal with curve trimming that occurs exactly on a node of the curve being trimmed.
- (FIX) Grid size was not updated in the view when loading a new file.
- (FIX) Make rotate command more consistent with the scale command to avoid “double rotation.”
