I am not a full time CNC person, I like to spread my time around Therefore I tend to forget things or might not use all the features on a regular bases.
C3D has great help and tutorials however I would like to see hints/reminders built in. The little question mark next to the field or the question mark that you drag over the field for quick reference hints, or a brief description. This might reduce some help requests / support questions.
I.E. for width, height, depth, radius Start Depth, Max Depth β¦ fields
Variables, (t,h,w), Formulas (w-0.5in), Conversions (mm,in)
Not sure if there are others, I forget them and I always want to type βinchβ instead if βinβ
For others it might just be a brief description of the feature.
This might clean up the screen
Also maybe the shortcut key map under the help tab.
That was awesome and it is so useful. so good that I was suggesting to add it to the help menu as it quick reference. I am not suggesting loading the program with large help files. C3D has provided awesome material. It was just quick hints as you hover over a field or click the standard β?β
Again in an attempt to reduce support questions.
You have also produce an awesome help guide. It was a great read that I still refer to. Thanks.
If you have not read it. Will did a fantastic job on it
