We tried to keep the UI as close to the 400 series as possible but all of the UI code is brand new so it might be a little wonky still. We’re no longer using the embedded web interface like the 400 series so this version should be more responsive and more maintainable going forward.
The biggest immediate benefits:
Better touch screen jogging on Windows
Unlimited gcode file size
Settings page should be more clear and bug-free
Persistent UI units (inch or mm, in the Settings page)
Faster start-up
Updated Shapeoko configuration makes the machine much faster.
Other than that, the function should be almost identical to the 400 series.
Be careful running this build and keep your hand on the power switch until it’s well-tested.
The load file dialog only allows for two file extensions, and of course I am using some other GCode generation tools that default to a different extension. Maybe you can allow a “.” search in the dialog as well? Leave the default to the 2 that are there already.
My laptop wants to run at a 1920x1080 resolution with the “Size of Text and App” set to 150%. When I do this there are screens (at least rapid jog and settings) that do not fit on the screen and you can not scroll down to the non-displayed area. You are just locked out. (At least I was when the app was maximized)
I liked using the gcode sending log while other operations were being run in Carbide Motion. This allows me to learn what the gcode commands really do… Now it is always on top of Carbide Motion and there is no way to stop and start the logging. It’s harder to use.
Got it. I’m not sure this one is something we’ll be changing in the short-term.
Because Carbide Motion is meant to be a “control panel” for the machines we make, we’ve scaled everything to be easier to view at arms length. If you have an additional 150% and don’t have a large monitor then it might be a problem because the application is effectively double-scaled. I think you might have to right-click on the Carbide Motion program icon and pull up the settings to disable the system-wide scaling for this app.
#1 is something we need to discuss with support. We’ve got a very broad user base and I think we’re better off with fewer, very well defined extensions for gcode to keep confusion to a minimum. If you have another extension that is commonly used only for gcode then we’d be more likely to consider adding it.
#3 - The log should not be on top all the time, we’ll have to look into a fix for that.
Hey Rob… I know you probably have heaps to do with CM using a new UI framework etc. But… if you could sneak in a tiny tiny modification such that the estimated duration (ie: 210 minutes) appends the ETA (ie: 201 minutes - 13:47) that would save me literally seconds of mental arithmetic (yeah, it’s minor… but hey, one has to ask )
@robgrz I can confirm scaling issues on Mac, also look at X+ and Y+ on the jog screen. Problems go away when I go to full screen… so that’s interesting.
Also do you have a list of new hotkeys? num pad + - are not working for my Z.
That “Time Remianing” field should be working on the “Run” screen. Are you looking for something different?
Yep, Qt. So far, we think everthing is working on the native code. QML and the embedded chromium window (both have now been purged from the code) scaled very poorly.
Do you have additonal UI scaling turned on in the operating system?
@robgrz Nope ‘default for display’ here’s two more odd things.
When Clicking Z+ with the mouse I had the software display the Z+ as persistently pressed with “Busy” flashing intermittently at the top of the screen. Z did travel in the + direction until it hit the limit switch. clicking anywhere in the UI released the Z pressed condition. I’m trying to replicate it so I can grab video but so far no such luck…
