Hello, I realize this had been requested before (link), but I wanted to bump it.
Often times when flip milling I’d like to reference the same corner when setting my WCS, but it’s inconvenient/impossible to put that corner in the bottom left or put the bitzero there due to workholding. I often then need to put the bitzero at a different corner and manually probe X, Y, Z - which wastes time and can lead to mistakes (I’ve forgotten to probe Y after probing X, or have mistakenly machined into my wasteboard because I forgot to move the bitzero on top of the stock and therefore set the Z offset 3mm lower than intended).
Given that a user can manually zero on other corners by going through the cycles individually, what’s the challenge in implementing directly in Carbide Motion as a one-click cycle?
