Carbide Motion Needs You!
Did you run
sudo apt update
sudo apt full-upgrade
for the version linked above?
Thought I had…but basically whatever I was doing with Apt caused the loss of the desktop GUI. So I re-imaged the microSD again. Performed an update. Checked with ChatGPT again & followed the instructions it gave. Got & installed the qt6 dependencies & now just managed to get CarbideMotionPi665 package installed - so now I’ll see if it works!
From ChatGPT:
I just finished a first try at making a 64-bit image and updating, and things worked as expected — hopefully that will still apply on take 2…
So even though CarbideMotionPi installed, it does not seem to want to run.
Trying to load it up via command line shows a library error - libQt6PrintSupport.so.6 - cannot open…no such file/directory.
sudo apt update
sudo apt install libqt6printsupport6
And tried running CM again - it runs!
Got as far as getting my backup machine settings loaded into CM & then tested that it makes connection with my SPROXXL & can initialize.
Could this be related to not being added to the dialout group? (grasping at straws)
I have a MB Pro 2013 version still running Mac OS…which can’t be upgraded. I bought a Seagate USB drive, installed Kubuntu linux and now boot from that, retaining the Mac OS. I have no issues with the original Linux CM via flatpack that was provided, everything works as advertised. I am waiting a little longer before upgrading to this newest Linux CM. I also installed the Windows version of CC (free) and use WineTricks so that I can have CC and CM running side by side on the Kubuntu instance and make any adjustments to C2D file as I work through the cuts. So far so good!
Thanks. I guess this means I’ll have to use Parallels to run the Windows version on my Mac to get the latest, eh? I don’t think anybody has software to run Apple silicon apps on Intel Mac yet, right?
So trying to get my 8bitDo Lite2 gamepad working with CMPi665 - it kind of still works but the button mapping is lacking & all over the place. Previous version had all the basic functions & the buttons mapped out decently enough on the gamepad.
So I’m just wondering what’s changed with that?
I’ve tried to re-map the gamepad, but it only partially works as whatever mapping CM has internally remains active & responds - which makes some buttons do 2 things or counteractive functions.
@Smorgasbord Or purchase a new Mac. I’m not aware of any effort to make Silicon apps work on Intel.
@Chaotica I looked into re-mapping game pads at:
It’s a lot easier to just purchase a Jog Pendant:
Running a severely outdated Microsoft Surface Go 2, and it seemed to work flawlessly. I did not go on to run a new operation, but I did open a file and inspect it in the 3D preview. Looks great.
Works great! I can load the view, move it around and does not crash.
Windows 11 Pro
|Processor|Intel(R) Coreā„¢ i7-6700 CPU @ 3.40GHz (3.41 GHz)|
|Installed RAM|16.0 GB (15.9 GB usable)|
|Graphics card|Intel(R) HD Graphics 530 (128 MB)|
|Storage|161 GB of 477 GB used|
|System type|64-bit operating system, x64-based processor|
I just had a go on my Raspberry Pi 4. Had to reinstall the OS as it’s incompatible with the OS I was on (Raspian from 2024). Got the new image installed and hit the same issue as @Chaotica
ā€œerror while loading shared libraries: libQt6PrintSupport.so.6: cannot open shared object file: No such file or directoryā€
Same fix by installing it with ā€œsudo apt install libqt6printsupport6ā€
After that, everything came up nicely and I have got my Shapeoko initialised and running with the new version. Haven’t tried to run a program yet so can’t comment on the 3D view today - hopefully will soon.
Finally got to loading up a test project to run - the 3D toolpath viewer works & responds nicely. This is on RPi5 with Trixie OS arm64.
Installed it on a GMKtex Mini PC N95 (8G), running Ubuntu 24 (Desktop).
Install required adding Flatpak for Windows manager (missing packages)
Had to add permission to USB (dialout group membership)
So far, no issues. It’s been responsive too (Better than Windows 11 on this hardware)
I updated my Carbide Motion and took a look at the rendering. It looks great, I was able to manipulate the rendering just fine.
I’m running it on my HP precision laptop with Win11.
Great job, I love it when a good plan comes together. Especially when it means we users can look forward to more cool updates in the future.
Worked for me, no issues Im on a older laptop, running windows 10
Runs great on a Windows 11 system. It is good to see it back again.
Works well Pi500 fresh Trixie 64 desktop install with the dependency noted above installed.
Thank you
The next Pi release should have that extra dependency explicitly defined in the package.
I also noticed that the Probing type selection buttons seemed quite a bit smaller as compared to the previous version.
One other change I had wondered about is an additional option for X/Y probe - often times I’ll probe a corner just for the X/Y. Probing each separately still requires the probing operation to check both axis which becomes doubly redundant when running them individually.
So far this Pi build has run really well on my first test job. I’m really curious how well the 3D viewer will function with a larger & more detailed toolpath.
Thanks for all your efforts Carbide3D!
