Okay I just down loaded the new version of carbide motion since I purchased the bit setter. How do I check and make sure the correct machine is set in carbide motion?
Please see:
Thanks WillAdams
Another question when I loaded the new version would I have to pick my machine again
Yes. The newer versions store many machine settings locally, so please configure everything, including Grbl (if need be, reset any customizations).
Where can I go to see what I need to do and how to refigure everything. All I did was load the new version. After I had installed the bit setter. Other then configure the bitsetter I didn’t do anything else.
