Installed 428 motion from 417 with HDZ . After initializing machine I no longer have soft limits in either direction of the x-axis. Y & Z are working. Should have left things alone.
Thanks !
Thanks !
Check this thread Carbide Motion 428 / HDZ / Suckit
Where can I find the older 417 cm download ? Like to revert back before I mess up something.
Was under betas. Looks like C removed it. No issue as long as you don’t rapid motion anything but center 3. Or skip rapid motion all together…
@WillAdams may know where 417 is hiding but as John says 428 works provided you don’t use positions other than Center but you can also use the return to X0Y0.
