Carbide Motion V6 Beta
You’d have to open the config file and change the travel limits manually (with CM closed so it won’t overwrite them). Click on the build number label to open the about box, then click “Open Data Directory”.
You’d have to go to the MDI and set the invert mask and then run the wizard again without sending the config again.
If you can send a video of this it would be helpful. I don’t think we have anything int here that could trigger that kind of delay, but it’s possible.
Did you read the first post?
For tiling and the bigger machines, we found out that almost nobody can reach the tool to change it in the middle if there’s a sheet in the way so we moved it closer to the BitSetter. This should have a minor time benefit as well since the spindle is staying close to the BitSetter.
