Carbide motion with Vectric vcarve pro
Hi, new owner of a Shapeoko 5. I am using Vcarve 12 to make my designs and then sending the gcode to the Shapeoko. Is there any way of seeing a cutting animation in this arrangement. If possible, i would like a simulation of the cutting files prior to being connected to my Shapeoko which is out in the shop.
thank you,
tony albano
wecarve.com
You mean beyond the simulation provided within VCarve?
Check out this thread about CM 637 from earlier in the day:
There are other gcode simulation packages out there that I have seen others on the forum mention but I have not tried any.
The old standby is NCviewer the gcode viewer.
Thanks! i had no idea there were gcode viewers. i will give it a try. Once Gcode is saved from the Vcarve and loaded into CarbideMotion. i cant open carbide motion with out the machine being connected. i will play around with a gcode viewer.
thanks!
thanks for sure going to look into this
yep, just what i was looking for. thanks!
