I want to carve a pocket that will drain water to one corner of the pocket, so I want a slight tilt in the bottom of the pocket. Is there a way to do this in Carbide Create?
I was thinking of mounting the workpiece with a small wedge under the corner that I want to the lowest point of the pocket as a workaround if a simple solution in CC is not available.
Mounting a small wedge is the most expedient solution.
Doing it in Carbide Create (not Pro) is rather tedious to set up — see:
Another option would be if you had a suitable V tool which was oblique enough to cut at the desired angle — I’ve done that for joinery, but it’s similarly tedious.
Doing it in Carbide Create Pro requires creating a much larger model than the inclined area and then setting the area around it to be equal, or drawing it up in greyscale and then importing a pixel image as a depth map.
which results in a diagonal drain that travels to the bottom right hand pocket (Note: This design had a pocket that was cut out, not modeled…so you would either have to model the bottom right corner or add regular milling to make the cutout)
I think this is what I will do (wedges). The most accessible software option looks like it might be TinkerCad–create the box, then add a wedge and combine. I am waiting for some wood for the final product here, may play around with MDF to see what works.
I used it to put together a library which emulates G-code:
and I’ve been working on using that with OpenSCAD Graph Editor:
and RapCAD:
It would be pretty straight-forward to make a file which would cut this — I actually blocked out making a module specfiically for such angled cuts the other day — if you’ll let me know the dimensions you are working with I could knock that out and provide a sample file, which would include generating G-code.
