Good evening. My latest project idea is to make an egg platter with the spots for the eggs routed out. Since I am using Carbide Create I don’t have a 3D option, but figured if I can get several tool passes that get smaller and deeper it would have a close enough effect for what I am doing. I spent some time working on the design and can get the shape with a little bit of extra sanding, but not as close as I want. Does anyone have any ideas how I can do this?
Thanks
egg test.c2d (116 KB)
Draw things up in profile — see:
and cut as a series of pockets.
Note that you can’t use even offsets — you need a series of them increasing — draw things up in profile:
and then measure each inset:
and repeat this until you arrive at something like:
egg test example.c2d (164 KB)
Thank you Will. This is exactly what I had banging around in my head, but I couldn’t figure it out. I never thought about doing the profile. You’re awesome.
Good Times
