The app crashes on OSX when I try to run the offset path tool. Running 10.14.6, and build number 451.
I’ve been using for a week without issues, but now I can no longer use this tool. Very bizarre. Any ideas?
It’s probably an open poly line you’re offsetting. If so, we fixed that bug today and we should have a new beta posted tomorrow.
It’s up at https://carbide3d.com/carbidecreate/beta/
Be careful- that build also has a new post processor system in it so keep your hand by the power switch when running code from it the first time.
Thank you Rob! That fixed the crashing. I’ll go run a job real quick to make sure there are no issues.
Thanks again.
