LOL, I’ll get right on it.
yes of course, what format do you want? DXF, DWG?
It’s a threaded tube at the end. I had some plumbing plugs, I drilled a hole for the pen lead to go through on one side. And on the other side, I put some foam to force the pen to stay down.
Depending on the length of the pen, pencil or marker, I put more or less foam.
Thanks! I’ll take anything you have.
dessin lego pour export 700x500.dxf (1.0 MB)
it will be only dxf, i can’t share a dwg. but anyway it works on all software
That looked like something I made using an idea I found on a video from a New Zealander. I used off the shelf PVC parts.
His inspiration was to use a foam ear plug for the ‘spring’ After accidentally running the foam ear plug through the washing machine it springs back very quickly. I added the dime to keep the ear plug from deforming.
Here is the break out of my version. This only accepts mini-sharpies.
The assembled device is clamped to the router body via the threaded rod with a hose clamp.
Thanks, Bill
yes indeed, I forgot to tag you on my previous post, I apologize. I was inspired by your idea.
thanks to you.
Bwood34
I’m glad you found the pen/plotter idea useful and easy to implement. Your drawing reminded me of the Jetson’s maid. My memory fails me as to its name.
Bill
New user so wont let me post more than one pic at a time. !
First time posting. Holder is made from hard maple took about 15 min to draw and cut. Split with bandsaw and inserted screw to tighten on spindle. Really solid and easy to use. Had to trim the back of it to miss the z rails.
I like your design Bwood34. I’ve collecting info from various drawing posts and I seem to like these types of designs the best.
Just a thought but could you incorporate a spring instead of the varied number of foam pieces?
Tyson:
As shown in my earlier post in this thread use a foam ear plug that has been washed in soapy water. It springs back quickly and applies just the right amount of pressure to a Sharpie.
Bill
yes indeed, I had thought about it, but I didn’t have one in the right size, so I have to look for one.
in the meantime, the solution of @72begin works too.
but for the one who makes this system, the spring is a good solution i think.
How flat is your bed that you are getting such consistent line widths over such a large area?
@baaja
my bed was surfaced, to obtain a good flatness.
I don’t have any measurements to give…
And to get better results, I put a cutting mat under my paper.
(brand “canson” paper I think it’s French, it’s a special paper for drawing, it’s thick).
Well I suppose the “spring” (foam in your case) does help a lot cancelling the subtle local variations in flatness, too. Much like the new diamond drag bit.
yes indeed. after I took the time to find the right height adjustment, not too much, low, not to make the pen drool. after the ball of the pen also compensates a little the defects of flatness.
