I wanted to try something quick and simple for bit changes. So I found this template in Carbide, added the text and setup the tooling. 1/8bit, 1/4 bit, and V bit. The material is Styrofoam.
I used double sided tape to hold it down, worked very well. I tried to make sure the bit didn’t go down too far because the tape will gum up the bits (found out the hard way).
Used spray paint for color, the black wanted to melt the Styrofoam. So, very quick light coats and it gave a cool weathered look.
