@ctdodge - Okay, got it, the dreaded Windows native zipping fun. There are a couple of things you can try. Please keep in mind that I’m not a Windows expert or support person though.
- Save the file, as you have done, then ‘Right’ click the file, select ‘Properties’ and from the bottom of the ‘General’ tab make sure that the file is not blocked. If it is, uncheck the box, click ‘Apply’ and then OK.
- Again, right click the file and see if there is an option to "Extract the file with one of the options listed.
If this doesn’t work, I would suggest downloading 7-Zip here:
https://www.7-zip.org/
Select the version based on your operating system 32-bit or 64-bit, install that download and retry the steps above.
Hopefully that will allow you to see excellent file that @Rafi put so much time into.
Gotten into a bit of a rabbit hole considering this is the Community Challenge, sorry about that folks.
