For years, I’ve been watching pros run milling jobs on a HAAS, in awe. With a little bonus I got, I decided to purchase a Nomad to finally start learning CNC.
I’m a lifelong SolidWorks user.
Any recommendations on a good for-dummies guide to learn how to CNC a SolidWorks model on a Nomad?
Your SolidWorks license may or may not include SolidCAM which would allow you to skip the STL — it’s supposed to be the same CAM tool as is bundled w/ some other commercial products, so other tutorials may apply.
I do have SolidWorks CAM. Just not really sure how to “directly” generate G-code. I’m really looking, if there is one out there, for a SolidWorks / HSMxpress tutorial that is specific to Nomad.
Everyone seems to be using Fusion 360 but I don’t want to get a new and expensive license for something that I already have/know/love…
that’s a bit out-dated (relies on Carbide Motion 3) and we no longer include the di-bond for cutting that (it’s messy) — perhaps one of the other tutorials?
Note that the wrench tutorial will be replaced by a tool-holder tutorial which is still in development.
It’s pretty straight-forward:
make design
create toolpaths
generate G-Code
connect to machine
send settings (if necessary — I don’t believe this has to be done on a Nomad)
initialize machine
secure your stock
install the first endmill
set zero relative to the stock by jogging the machine to where you want to origin to be
load and send file
If you get stuck, just post here or at support@carbide3d.com and we’ll do our best to help
Just to set expectations, I don’t think there’s a straightforward “SolidWorks for Nomad Dummies” that you could use. I think the overlap between SolidWorks users and Nomad users is quite small, as Nomad is a hobby machine and Fusion 360 heavily dominates among hobbyists due to the free option.
Aside from that, you’ll have to set up the machine in SolidWorks (which should mostly be a matter of looking up specs) and find some comfortable feeds and speeds. If you’re working with metals, the Nomad (at least the 883 Pro, it wasn’t clear which Nomad you have) can be quite picky about those because of its puny frame and spindle (relative to the machines your pros are working on), so I’d recommend looking at Winston’s fantastic MaterialMondays videos to get an idea of what feeds and speeds to use.
All that said, you can also just use another program for CAM, like MeshCAM or even Fusion 360. You’ll have more resources available that way.
What version of Solidworks are you running? I have 2018 and found the CAM side a little clunky, Meshcam is likely a good option starting out but I’m not sure what filetypes it can import. I’ll have a bit of a play and see if I can help out at all (I have a shapeoko but it will be similar workflow).
Maybe best is to start with some pocket cuts and get the process sorted, then progress into complex models.
I’ve just started playing with it but it’s actually really cool. In particular, it can auto-detect features for you and set up the toolpaths semi-automatically. Plus, tolerance-based machining looks interesting.
@WillAdams, I see everything clearer now. Looks like my path is like so:
learn CNC feeds-and-speeds with the built-in suggestions of the Nomad + MeshCAM
when comfortable, start playing with feeds-and-speeds of my own “design”
let the Nature take its course as I graduate to more powerful software and, perhaps, CNC machines.
I happen to be a member of www.nextfab.com here in Philly. They have a HAAS, running off SolidWorks + HSM Works. My dream is to make a cut on that machine and it looks like the path to that is clear.
@Moded1952, SolidWorks is yet to fail me… From the video tutorials I’ve reviewed it looks to be pretty crafty. Just need to get HSMXpress to work and, well, receive my CNC (it’s on backorder right now). Soon!
The great thing here is the default mode for Nomad use in MeshCAM is a completely automated calculation of this based on the material and tooling selected.
You should be able to use that as a starting point and then you can learn chiploads and look into spreadsheets and calculators. G-Wizard is mentioned favorably in:
FWIW, though it might be great for larger machines, I haven’t had any luck with the calculators on the Nomad, at least milling metals. The machine has great difficulty performing anywhere near its rated specs, which seems to confuse the calculators.
I’ve heard of some people around the forums using HSMAdvisor though, maybe they have better luck than me.
