Working on a project and have been struggling with designing this logo. I cannot for figure out why none of my Booleans aren’t working. How do I get the lines from the “world” BEHIND the hand and wrench? I always randomly seem to struggle with this function when it comes to multiple lines intersecting, until I get lucky enough to push the correct sequence. Not this time.
Can someone also explain as to why these are so difficult at times? I also attached the file.
Assuming you want to join the vectors so they are cut as a single carve, Select the wrench, shift-select the world vector near the wrench so both are selected. Then select Boolean → Union
This is what I am going for. I made an offset to the outside of the fingers in the hand to make the wrench and world appear behind the hand. But cannot seem to do it again.
