Suppose the there is some discrepancy between dimensions in carbide create and what is executed by machine, I.e. due to some error in squareness or other dimension. Is there a compensation adjustment in carbide create to correct these so that subsequent dimensions are corrected. E.g. let’s say you draw a circle, but machine cuts a very slight ellipse where say the X diameter is a fraction of a percent different from the Y diameter. Is there a correction function that can be tweaked to offset this error so now other figures are correct in XY?
Not directly. For dimensional discrepancies you could use the Scale function. For squareness you would need some kind of Skew/perspective function.
But the real solution is to calibrate & square your machine.
Which machine do you have?
If you have a belt-drive machine see:
For an error in squareness you’ll need to unbolt things, square things up, then re-tighten all the hardware (ensuring that nothing pulls things out of square while doing so)
I didn’t think of this when putting together my machine. I thought it would come together much more square then it did. When I finally went back to check squareness, I was shocked to find that my machine was out 3/4 of an inch out of square. I had to go back and remove all of my spoilboard slats, loosen all the T railing screws, square up the machine and tighten back all of the T railing screws. Then I rechecked squareness and then reinstalled all of my spoilboard slats.
I was having some funny cuts happening that, upon further investigation, and community posts, that my machine was probably not square. Now I will need to tram my spindle to my table and then surface my table, but that will be down the line when I get back home to the shop and can get a double indicator tramming tool.
