Curious on how to approach something like this on CNC?
How a part once designed is machined is a topic which runs up against:
  • stock size and machine working area — certain orientations may not be possible due to Z-axis limitations
  • workholding — how will the stock be clamped/secured?
  • will a fixture be needed for one or more additional operations?
  • tabs/sprues — will it be necessary to add tabs/sprues if a fixture alone is not sufficient?
For an example of one approach to this sort of thing see:
Note that there are entire books written on jigs and fixtures:
The search term you want is “Design for Manufacturing”.
