I have a few simple rectangles I need to cut out of an 1/8" thick sheet of aluminum, rather than cutting with my jigsaw I figured this might be a great job for the shapeoko.
Looking into some of the threads here I am a little unsure as to how it’s going to go when I pull the trigger… This thread shows there’s somewhat of a glitch in the software when it comes to feeds and speeds. Does anyone know if this is still the case?
I had to go back and check what I was annoyed by
It was the fact that at the time, CC had no adequate Shapeoko-compatible recommended feeds and speeds in its library. This was fixed long ago, so it’s all good now.
Seems like I should be ok with the carbide tip bits I already have and keep the surface lubricated?
Should I be tensioning my belts more than what they already are? I already went through the trouble of tensioning them just right with the app that measures the audible noise of the belt when I flick them…
I use Estlcam to generate all of my 2D or 2.5D work.
75mins seems long to me - so I drew up a 230mm X 380mm rectangle, put it in Estlcam to generate my gcode with my typical settings (used a 4mm end mill in this case), and I could do that in under 13 mins, with trochoidal roughing pass and then a finishing pass - both full depth.
Here is a screen shot of the tool paths and timing:
I highly recommend Estlcam if you don’t know of it. Reasonably priced, and there is a Shapeoko post processor built in, very easy to get it going. I have no affiliation - just a big fan.
