WillAdams
(William Adams (Carbide 3D))
2
If you have Pro, you can model this.
In the base version of Carbide Create you have a couple of options:
- source a “bowl” bit of the correct diameter/rounding, clear the bulk of the material, then make a final pass w/ the tool
- approximate it using a series of cuts w/ a ball-nosed endmill
