I want to cut a cone (or funnel) into a material. Can either Carbide Create or CC Pro do it? From what I’ve read it looks like only CC Pro can do it, via 3D Vector option. Thank you
It can be done with PRO, see: Spoon Possible without CC Pro?
Or use a V-bit with the appropriate angle for your cone.
With PRO, it can be modeled and cut with a 3D toolpath. I’d recommend 3D rough path with 0 stock to leave and a shallow depth of cut for a finish cut.
thank you. I appreciate it.
I just tried it.
Rough: 3D Rough with normal depth & stepover & stock to leave
Finish: 3D Rough with small depth, stepover bigger than the hole, 0.0 stock to leave
Looked good
